Ir para o conteúdo principal
Processador quad-core Intel Core i7 de 2,0 GHz, 2,3 GHz ou 2,6 GHz (Turbo Boost de até 3,8 GHz) com 6 MB de cache L3 compartilhado.
MacBook not turning on
Hey all! I was installing macos mavericks on my macbook, when it suddenly turned off and refused to turn back on again. The charging indicator shows that its charging thogh (the orange and green light) but isnt actually on. What can i do to fix it or what can be the cause? Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Let's try a hard SMC reset.follow this guide to Step Substituição da bateria do MacBook Pro 15" com tela Retina do final de 2013 now with nothing plugged in press and hold the power button for a good 15sec's this will discharge the logic board. Now carefully plug in the MagSafe charger only, the system should spontaneously restart, let it complete the process and do a clean shutdown. Now carefully reconnect the battery and with the MagSafe charger also connected see if that works if it does, shutdown and disconnect the charger and test again. If any of these fails let us know.
Esta resposta foi útil?
Pontuação 0
3 comentários:
Hey til what step? I think your text glitched a bit
por
I figured it out and tried your steps. Didn't work. However when i plugged the charger in and let go of the power button, it turned green, then it went back to orange
por
@zarrar_ - I if it stays Amber, the battery needs to be charged and might need replacing as well. Let it sit a good four hours, then try to turn it on then.
por
Adicionar a sua resposta
Zarrar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 174
