Ir para o conteúdo principal
A oitava geração do Mitsubishi Lancer.
2002 Lancer CK5A Window not reciprocating
I've bench tested the regulator and it's working. The switches driver window relay clicks in both switch directions yet the window still doesn't move. I'm open to any ideas or wiring diagrams.
Cheers team.
Esta é uma boa pergunta?
Pontuação 0
4 comentários
@andrewmorg21490 "bench tested the regulator " is that including the motor? Besides clicking, have you checked the relay?
por
Yeah, motor works as it should. Moves the cable up and down on its path. I'll take the switch apart and come back.
por
The "auto-sw" arm was in the wrong position making the switch not work at all. I'll put it all back together and see if it stays fixed 🤣
por
Looks good and works good. It's a silly little 3mm plastic tab the switch is meant to hook on to. Out of all things...
por
Adicionar um comentário
1 resposta
Solução escolhida
It's a little ~3mm plastic tab the switch is meant to hook on to, and it should be aligned with the outline on the PCB.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Andrew Morgan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 17
Ao todo: 244
