Ir para o conteúdo principal
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor uses DDR3 RAM and has 256mb of VRAM. Gpu is FX 9400m
No startup chime/audio greyed out on late 2009 Mac mini?
On my late 2009 Mac mini (Lion 10.7.4) the audio is randomly greyed out without any startup chime. In System Preferences/Sound/Output, no audio output device is shown.
What could be the problem?
Esta é uma boa pergunta?
Pontuação 1
4 comentários
Has the unit ever been operated on?
por
Yes.
Just wondering. Could it be related to overheating?
por
This doesn't seem like it would be related to overheating.
por
I’m having the same issue with my late 2009 Mac Mini, which is on the last officially supported OS, MacOS X 10.11.6. I have another more upgraded one that isn’t slow that does have audio, but isn’t booting.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
You may have a damaged or disconnected audio board. Use this guide to open the computer and get to the board. Check the ribbon cable coming from the interconnect board is connected to it. If the cables aren't the problem, you may need to replace the board itself. Here is one for sale on eBay, as iFixit does not sell them.
Esta resposta foi útil?
Pontuação 2
If you have upgraded your OS to Lion or (especially) Mountain Lion, this can cause your problem. Look in Apples support section for details, but all I had to do was reinstall the new OS... Problem solved.
Pontuação 0
Adicionar a sua resposta
Michele Carlo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 38
Ao todo: 3,639
