Ir para o conteúdo principal
O headset de realidade mista Meta Quest 3S foi lançado em 15 de outubro de 2024 e é um irmão mais novo e compacto do Meta Quest 3.
How do I fix my stick drift?
I’ve had my Meta Quest 3s since December 31st. Its August 21st as of this being posted, It’s been about a week and i’ve had really bad stick drift issues, especially on my right controller. i’ve tried to recalibrate and clean my controllers, like the official guide says, but i’m still met with issues. What can I do without completely replacing my controllers? help!
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
3 respostas
Pergunta mais útil
What kind of alcohol did you use when cleaning them? If it's not 90% you won't get the result you want. Can you give me more details about the issue?
Esta resposta foi útil?
Pontuação 2
1 comentário:
In terms of the alcohol i probably didn’t use 90%. unfortunately i don’t remember. i mean, the drift isn’t constant, however, i’m finding that after about a half ish hour of using my headset with the controllers, the drift persists after that. I stopped using it for about two months, came back to it yesterday, and nothings fixed it. i cleaned it again thoroughly changing the batteries and AGAIN, recalibrating the controllers. i guess i’m kind of stuck now. I’ll see if the 90% helps though! thanks!
por
So on my quest 3s left controller when I use a certain move on the thumbstick,example going backwards it just doesn’t let me go back same thing with the other direction that are provided to use in order to move.ive used alcohol wipes even my mouth to blow air out but nothing works so this is my answer
Pontuação 1
3 comentários:
Watch youtube video "3 способа исправить дрифт стика на Oculus Quest 2".
I've used method2 but without disassembling. It helped
por
Thanks guys! Update: My stick drift has gotten.. worse. 😭. My friends are telling me I can use compressed air to clean them or, ultimately, replace them. But that is NOT happening anytime soon. Trial and error, I'll see what the video can do to help me.
por
@alexanderpakizh I don’t understand that language
por
how to fix my 3s vr
Pontuação 0
Adicionar a sua resposta
carousel0w será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 54
Últimos 30 dias: 171
Ao todo: 2,884
