Ir para o conteúdo principal
Poco M4 Pro 4G Lançado em 16 de março de 2022 179,5 g, 8,1 mm de espessura Android 11, MIUI 13 para POCO Armazenamento de 64 GB/128 GB/256 GB, microSDXC
Charging problem to my phone
When I put my phone on charge it is not getting charge faster and having automatically charging on and off problem why it is happening?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Hey there!
If I had to assume, I would say that your charging port has a bad connection to its PCB. Before you open it up to look, however, make sure you try a different cord and/or a different wall outlet to make sure they aren't the problem. I would also check your settings to see if you have "prioritized charging" or something along those lines turned on. The setting could be making your phone not charge at certain points.
If you have confirmed that everything I've listed isn't what's wrong, I would either open it to see if the charging port is bad, or even take it to a local repair shop to have it looked at.
Best of luck!
Esta resposta foi útil?
Pontuação 0
Poco m4 pro 4g speaker was filled by dust
Pontuação 0
When I put phone on charging charging was soo slow
Pontuação 0
Adicionar a sua resposta
Bm amer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 659
