Ir para o conteúdo principal
O controle do Xbox One foi lançado em 2016 com a chegada do Xbox One S e adiciona suporte a Bluetooth para Windows 10/11. Este controle corrige muitas das falhas de design encontradas nos controles Modelo 1537/1697 e é muito mais confiável. Este controle foi substituído pelo melhorado controle Modelo 1914.
How can I make it turn on?
It seems a battery exploded inside the port and calcified the connector and it's surroundings. I already cleaned it as best I could with a bit of alcohol but it doesn't seem to register that it has batteries, even though I put in fresh ones. That being said, when I connected it to my laptop through cable it seemed to receive power and turn on.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi Alex!
Oh my... The only thing you can do is to clean it with isopropryl alcohol. The whole motherboard, but this is what you already did.
So, the next step is to replace the battery pins for new ones! Soldering is required, but it's not that difficult.
If that didn't worked, then there is something (or more things..) damaged on the motherboard. If this is the case, it's probably not worth to repair it. Sorry.
Hopefully replacing the battery pins will do it!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Alex Gonzalez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 132
