Ir para o conteúdo principal
Informações de reparo e guias para o iPhone 6s Plus, lançado em 25 de setembro de 2015. Modelos A1687, A1634
Phone stuck on bootloop
Tried restoring/updating with iTunes and 3uTools with latest ios.
On 3uTools trying to "Fix Flash", it stops at 34%, on the "Updating NAND Firmware", after the phone shows the Apple logo and the update progress bar, then it hangs for a minute then reboot and returns to restore mode.
20:55:10.254:  Requesting SHSH
20:55:11.234:  Enter Recovery Mode
20:55:15.774:  Sending AppleLogo
20:55:15.803:  Sending Ramdisk
20:55:24.207:  Sending DeviceTree
20:55:24.222:  Sending RestoreSep
20:55:24.350:  Sending KernelCache << reboot to restore mode with the "Quick Flash"
20:55:32.333:  Restoring
20:55:34.497:  Sending RootTicket
20:55:34.501:  Waiting for NAND
20:55:34.514:  Updating NAND Firmware << reboot to restore mode with "Fix Flash" after 1 minute.
The battery was replaced 5-6 years ago, can this be battery related or a NAND failure?
Noticed that from uTools, if I launch a standard "Quick Flash" the phone reboot and goes back to restore mode after the "Sending KernelCache".
If I use the "Fix Flash" mode, it reaches the "Updating NAND Firmware" before going back into restore mode after 1 minute and no visible progress on the bar.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Update: Replaced the battery and the phone has same behavior.
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
I'd fit a new battery then try it if it's 5 or 6 years old. Also could need a new charge port if it does the same thing after a new battery. Older iphones can bootloop if the front camera ribbon develops a fault so it might be worth a try disconnecting it then trying to restore.
Esta resposta foi útil?
Pontuação 1
3 comentários:
I was considering that but wanted to be sure it could be a battery fault and not a NAND or other problem, since i'll then remain with an unused full battery and a not working phone.
por Compartilhar
Were you able to get it working again? If so, how did you go about it?
por Compartilhar
@emerald83404 Replaced the battery, but the problem persists. Probably need a NAND reball / replacement but I have no instruments to do it.
por Compartilhar
Adicionar a sua resposta
Anachron será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 52
Ao todo: 1,205
