Guias de reparo, informações de desmontagem e solução de problemas do EliteBook 840 G8 da HP, um notebook empresarial lançado pela HP em dezembro de 2020.
Navegue neste tópico para encontrar o local apropriado para este comentário. Em seguida, clique em “Anexar comentário a esta postagem” para movê-lo.
2 comentários:
@modulandi why do you think it is the Audio IC? What have you checked? What exact model is your motherboard? Usually you'll find a couple numbers printed on the top side of the board. The most common audio codec for your model is a REA_ALC3292 and it is soldered on the top side of your motherboard.
por oldturkey03
@modulandi what had you tried?
btw you can try this.
download and run HPIA
https://ftp.ext.hp.com/pub/caps-softpaq/...
Click on Analyze
Allow for some time for the system to complete the discovery.
click on recommendations tab when discovery is complete.
check on the the items that is recommended to install. especially on audio drivers.
click download.
select on the radio button, download softpack, extract files and install.
once done, your pc will need to restart to update bios and misc.
por Augustine
