Ir para o conteúdo principal
Fix bezel which separated from screen during battery replacement?
Hello,
Using iFixit parts and repair guide, I am replacing my Pixel 6 battery. During disassembly, the bezel separated from the screen despite my efforts to prevent this. How can I fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Late to the post by a year, but came across in my quest to find an answer. I kept my phone together with 2 thick rubber banks that I save from produce (broccoli) to hold my phone together while I waited for an adhesive order from Amazon. My bezel pulled half off when removing the screen. I ordered t-7000 (black) adhesive and worked great to reattach. I then used the oem adhesive sheet and placed some thick sheets under my phone to level with the camera on the table. Then a board and book on top for a hour to let the adhesive(s) set.
ifixit should really sell and suggest a small tube of T7000 with the kit in case it's needed.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
James B será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 114
