Thunderbolt display cutting out intermittently, possibly heat related?
I've been using my Thunderbolt Display daily for 13 years without any issues—until last week. Suddenly, it started cutting out and not turning back on as if I had unplugged it.
Symptoms
- The display shuts off randomly, but more frequently when my MacBook (late-2012 Retina) is closed.
- When closed: The display cuts out every 1–2 minutes or less.
- When open: It lasts 2–5 minutes before cutting out.
- If it cuts out while closed, the MacBook screen stays off until I unplug the display.
- If it cuts out while open, the MacBook screen remains on like normal.
- Moving the MacBook away from directly under the display significantly reduces the issue.
- Speakers will continue playing music, peripherals continue charging or maintain connection, macbook remains charging from the TB cable. No interruption when the display cuts.
Troubleshooting
- Checked, unplugged, and cleaned all cable connections.
- Updated my OpenCore Legacy Patcher (OCLP) build and patches.
- Reset NVRAM/PRAM—but I didn’t hear the Thunderbolt Display fan cycle.
- Noticed the display feels warm.
This makes me wonder if it’s heat-related. Since the issue improves when I move my MacBook away, I’m thinking the Thunderbolt Display’s cooling system might be failing or the heat from the MacBook is affecting it.
Does anyone have insights or similar experiences? Any suggestions on what to check next?
Esta é uma boa pergunta?
