Ir para o conteúdo principal
Guias de reparo, suporte e informações de resolução de problemas para o MacBook Air de 13 polegadas de março de 2024, equipado com o SoC M3 da Apple. Lançado em 8 de março de 2024 e identificado pelo número de modelo A3113.
Screen panel closing issue
I have an mba purchased in october of the last year. I have noticed today that when I close the screen, it will not remain closed at all. Is this normal or it is an issue and I need to get Apple service?
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sounds like either the uppercase has warped a bit or the lid hinges are out of alignment.
Make sure you don’t have a snap-on shell as these have tabs to hold them on the gap between which is to narrow and all you do is crack you display. I only recommend skins which are more than enough for most.
Esta resposta foi útil?
Pontuação 1
22 comentários:
I didn't use a shell and since I bought it, rarely I'v closed the lid, maybe at least 6/8 times. I'm a bit worryed
por
@ziobru Do you use a Keyboard protector or one of those webcam sliders?
por
I have a keyboard protector but it's very thin, I've tried to remove it, but the problem still remain
por
@ziobru - as your system is likely still under warranty I would head over to the Apple Store to see what they can do. But leave the keyboard protector at home.
por
I purchased it on the mediaworld online store and not into an Apple store. I don’t know if Apple will give me support directly. I sended today a mail to the support of the online store to understand if I can get warranty from them or I will need to go to an Apple store
por
Exibir mais 17 comentários
Adicionar a sua resposta
B1P será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 16
Ao todo: 398
