Thunderbolt 2 built in cable replacement
It is possible to replace a damaged built in Thunderbolt 2 cable in a LACIE Rugged SSD?
Esta é uma boa pergunta?
1st you need to look at this video and determine if you can disassemble it.
Then you need to determine what kind of cable you need. I can't tell how it connects to the PCB.
Then you need to see if you can find a match cable. Then reassemble.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 291
