Ir para o conteúdo principal
Manuais de reparo e informações para desktops tudo-em-um Surface Studio da Microsoft.
Screen swap for Surface Studio
I have an original Surface Studio. I can buy a screen damaged Surface Studio 2+ for a couple of hundred dollars. I would like to swap the damaged screen with the functioning screen from the original Surface Studio but do not know if the connectors are the same. I like the 2+ because of the added Thunderbolt 4 ports. Is this possible?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
After looking at photos between the two, I’d say there is a very good chance that the displays are swappable. Unfortunately, there isn’t many photos of the connector pins or connection seats themselves, so I can’t guarantee that it’ll work. It would definitely be a calculated risk.
If you need help installing the display, see the official Microsoft service guide.
Surface Studio 2+ English Service Guide
Esta resposta foi útil?
Pontuação 0
I have a broken screen Surface Studio 1 and a lesser unbroken Studio 1. Is it possible to swap the two between two of the same model? Is there a guide anywhere? Is the process the same as the Studio 2+ they posted online?
Pontuação 0
Adicionar a sua resposta
Dan Lord será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Ao todo: 313
