How do I unblock the hot water outlet from calcium buildup/
The water from the faucet does not come out from the Hot side. It is blocked with calcium deposits.
Esta é uma boa pergunta?
The only way to remove the lime buildup is either physically chipping it out or using a solvent.
You might be able to get to the blockage by removing the vale assembly if it’s within the faucets hot water line. You may need to soak the faucet in a tub filled with a lime removal solvent. Grohe Einhebelmischer Mischpatrone Replacement here’s one safe solvent Lime Away
The faucet valve unit should be a replaceable part if it is damaged.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 12
Duração total: 12
