Ir para o conteúdo principal
Repair and disassembly guides for the Huawei Honor smartphone line.
20 Perguntas Visualizar todos
What kind of display?
I have a honor view 10 and the problem is that 1. there is no specific tutorial for it but I will just follow the honor view 20 guide. But in this the author says I have to you use a screen without the frame but 2. the cracks are also over my back camera which I think is part of the frame. So which kind of display should I buy? A lcd with only touch or a lcd with a frame?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@jcb77 it is always easier to change the display with the mid frame. I would suggest you use the guides from here It will show you how to replace the screen with the midframe. They are written in Spanish so use a browser that does the translating for you (if needed)
About your rear camera, that is a different frame and you may need to replace the back of your phone. Hard to say since we can't see the damage :-)
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this. Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
JCB_77 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 10
Ao todo: 10
