Ir para o conteúdo principal
Processador quad-core Intel Core i7 de 2,2 GHz (Turbo Boost até 3,4 GHz) ou 2,5 GHz (Turbo Boost até 3,7 GHz) com 6 MB de cache L3 compartilhado.
Touchpad not found after replacement
Hi all -
Original symptoms were short battery life and touchpad physical clicking not working. I bought a replacement battery and touchpad.
Battery was definitely bulging and putting pressure on the touchpad. I swapped out both and when booted back up - no mouse movement or clicking at all from the touchpad. External mouse works fine, so I went into system preferences and then Touchpad. It said "Touchpad not detected" or something along those lines and had a spinning circle indicating that it was searching for bluetooth touchpads.
So I opened it back up and swapped in the original touchpad - mouse movement but no clicking. But still, system preferences says it doesn't detect a touchpad (I was hoping to at least turn on tap to click.)
So, what am I missing? Is there some extra step to set up the touchpad with the OS? Does the lack of movement on the replacement pad mean that it's DOA?
Thanks for any help!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Did you also replace the trackpad cable with the trackpad MacBook Pro 15" Trackpad Cable (13/14) the cable holds the interface chip which can get damaged.
Esta resposta foi útil?
Pontuação 1
4 comentários:
Yes, the new trackpad came with a new cable. I haven't removed the cable from either pad, just disconnected from the logic board
por Compartilhar
@agitatedgopher - Try replacing the cable with a fresh one. I’ve hit a few bad ones as I suspect the chip is a bit static sensitive (ESD).
por Compartilhar
Oh, I forgot to come back here, but yes, that fixed it! Went to a mac repair shop, showed them what I needed, the guy in the back who knew everything got me a cable, and I forgot what they charged me for it, but it's working happily now.
por Compartilhar
@agitatedgopher - That's Great! Don't forget to score and accept the answer so others find the solution. Thanks!
por Compartilhar
Pergunta mais útil
Have a look at the Substituição da placa lógica do MacBook Pro 15" Retina Display Mid 2014 & check step 25 for the touchpad connection to see if it is correctly seated. This maybe your issue.
Pontuação 1
2 comentários:
Well, that was the first thing I tried, reseating the connector. Still no change. Then I reinstalled the original pad and got mouse movement, but it still doesn't show up in preferences. Then I switched back to the new pad and it's still no movement and not showing up in preferences
por Compartilhar
@agitatedgopher Hmmmm.... Maybe @danj can give some thoughts....
por Compartilhar
Adicionar a sua resposta
AgitatedGopher será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 15
Ao todo: 287
