Ir para o conteúdo principal
Repair and Disassembly guide for the 2020 ASUS G15 G512LI, A laptop produced by Asus for budget/light gaming.
monitor flickering when opening and shutting
so ive had this problem for a while but i ufnored it and its kinda getting worse .
when i wanna change the angle of the monitor it starts flickering and when its in a fixed position its fine i think its the ribbon cable that goes through the hinge but i dont have warranty and if it only needs a blow for dust or readjusting the connector i dont wanna pay extra for that ( i also dont trust the repair shops in my area with this laptop). so is there gonna be any problem if i open the laptop myself watching a yt video or am i gonna mess it up cus im kinda inexperienced?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Hi @amirhossei52737
The most important thing to do when working inside a laptop is to disconnect the battery cable from the motherboard, as soon as you can access it after opening the laptop.
Doing this will minimize any electrical problems from occurring whilst doing any repairs.
There's always power on a motherboard somewhere even when the laptop is turned off. The Power button is not a power isolating button. Its function is to signal the intentions of the user to the BIOS/OS what to do, e.g. turn on, wake up etc.
Mechanical and ESD damage e.g. tools slipping physically damaging components etc or fingers/hands touching sensitive components is another problem so be careful when you're doing any repairs and take your time doing them. Wearing a wrist strap, connected to a suitable earth point will help to avoid causing ESD damage.
Here are two videos that will help to check if the cable is OK or not.
Here's a teardown video that may help. The battery can be seen being disconnected at 4:50 minutes into the video. Don't do like the person in the video and touch anything else before disconnecting it as soon as you can access it.
Here's a video that shows how to replace the display in the laptop which shows where the cable connections are in the motherboard and the display. The person in the video may be wearing insulating gloves but my view that it is always safer to disconnect the battery first (which they haven't done) and only reconnect it, last thing before closing the laptop for the last time.
If the EDP cable is damaged the best that I can find out is that the Asus part number for the EDP cable is 14005-03070000 (examples only). Search online for the part number only to find suppliers that suit you best. Note: the same cable is used for a lot of different Asus models and perhaps that's why the seller may not list your model as being compatible, as they may not know this.
Esta resposta foi útil?
Pontuação 0
It sounds like the issue is with the ribbon cable running through the hinge. Over time, these cables can become loose, pinched, or damaged due to repeated opening and closing.
Since you’re inexperienced, opening the laptop carries some risk, but if you’re careful and follow a good guide, it’s doable.
  1. Watch a Disassembly Video for the ROG Strix G15 (G512) before attempting anything.
  2. Use Proper Tools – A plastic prying tool and small screwdrivers will help avoid damage.
  3. Check the Ribbon Cable – If it looks loose, carefully reseat it. If it's torn or frayed, replacement might be needed.
  4. Blow Out Dust – Use compressed air to clear any buildup near the hinge.
  • If you see exposed or damaged wires, the cable likely needs replacing.
  • If flickering persists after reseating, the issue may be deeper (LCD cable or motherboard connection).
Since you don’t trust local repair shops, taking a careful DIY approach is understandable. Just be patient and work slowly. Let me know if you need a repair guide recommendation!
Pontuação 0
Well try the following:
  • Check Connections and Cables
  • Update Graphics Drivers some time any outdated can be the cause of this issue.
  • Adjust Refresh Rate of your laptop
Pontuação 0
Adicionar a sua resposta
AmirHossein Heidari será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 181
