Right Trigger RT stopped working
RT stopped working. If you turn the pad up side down , RT worked for some time. Now , RT is completely dead.
What could be the reason
Esta é uma boa pergunta?
Hi it is hard to say without inspection
From the description you provided sounds like perhaps a mechanical failure of some kind, since the gamepad uses a hall effect triggers it is possible that the hall effect sensor broke
But as previously mentioned hard to say without inspecting the controller internally.
Esta resposta foi útil?
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 20
Ao todo: 389
