Stuck HDMI port during replacement
I’m trying to replace my hdmi port on my Xbox series x. I’ve been using low melt solder, flux and heat. The silver covering of the port came off but the actual port will not budge off the motherboard. Any suggestions?
Esta é uma boa pergunta?
Hi!
What kind of tools do you use? A heat gun? If yes, what is the temperature? Do you have the brand and types of tools you are using? Thanks
por koppie007
I do use a heat gun. It doesn’t have a temp control but says it gets up to 750 degrees it’s ever start brand and I have a soldering iron as well that I bought off of amazon
por Bridget
That should be fine. It should come off. Even with 550. So I think something is wrong with the heat gun. Can you share a video with us? Thanks!
por koppie007
