Hey dont it run
The motor do not run
why
Esta é uma boa pergunta?
Steffen, you're not giving us much to go on. You say the motor doesn't run; does it do anything else? Is there any kind of indicator light that comes on? There's a red indicator light beneath the warning sign to the top left that can indicate an overheat condition or a damaged overheat switch. If that light is on, I suggest you read up on the vacuum cleaner disassembly guide here.
Miele S828 Vacuum cleaner Disassembly - iFixit Repair Guide
Otherwise you will have to do some basic troubleshooting. Can you use a voltmeter and an ohmmeter? If so, you'll need to disassemble the vacuum and test the power switch then check to see if the motor is getting power.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 269
