Ir para o conteúdo principal
Repair guides and disassembly information for the Samsung Galaxy A51 Android smartphone. Released in January of 2020.
20 Perguntas Visualizar todos
Why the phone goes dark screen suddenly
Why my phone goes dark screen while using it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@michelebolton if it is just the screen that turns black while using it, then check the proximity light sensor. Use the instructions from the Samsung site for that. If that does not resolve it, you may either have a bad sensor or a bad Sensor Flex Cable
If it is an issues with the adaptive brightness thn you go to settings>apps, then enable show system apps then search for a system app named "BrightnessBNR" and then clear that data. To find that system app make sure that you enable " "show system apps"
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Michele Bolton será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 13
Ao todo: 13
