Ir para o conteúdo principal
Data de lançamento: Fevereiro de 2018 Sistema: Android 7.1.2
How to replace the power button
Replacing the power button
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Lawang Kayu, there are two parts to the buttons; there is the little circuit board that the switch domes are mounted on, then there are the physical buttons you push to activate those domes. It's not clear from your description which part is the problem so I can't tell you exactly how to fix it.
That being said, even though iFixit doesn't have a guide to repairing your phone, there's a Spanish site called Nadie Me Llama Gallina that has guides for both repairs - exactly what you need. It is, as you may guess, written in Spanish but has language translation available so their guides are quite usable and well done. Here are links to guides for both the electrical and the mechanical parts.
Manuales / Xiaomi Redmi 5 Plus / Side push buttons - Nadie Me Llama Gallina
Manuales / Xiaomi Redmi 5 Plus / Side keys - Nadie Me Llama Gallina
As I mentioned, I can't tell you which one is going to fix your problem, but you're covered either way.
Good luck and let us know how it turns out!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Lawang Kayu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 24
Ao todo: 369
