Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para a quarta geração do controle Sony PlayStation 5 DualSense, sucessor da série DualShock. Identificado pelo número de modelo CFI-ZCT1W e modelo de placa-mãe BDM-040.
How do I fix stick drift?
Cursor on screen is constantly slowly moving upwards, any solutions to resolve?
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Hi! You do need to replace the joystick it self if you are experiencing drift! Which stick is it? Right or left one?
por Compartilhar
Adicionar um comentário
2 respostas
Test it before you open it - plug into a PC, watch the resting value hands-off for 30-60 seconds. Healthy is near 0.00 with a tiny wobble. If it's a steady offset, reset + firmware first, then clean around the base with a damp 90%+ alcohol swab while rotating the stick. If that only holds a day or two, the track is worn - cleaning won't rebuild it, that's a module swap, and check warranty before opening because opening usually voids it.
Esta resposta foi útil?
Pontuação 0
My stick drift was caused by wear and tear in the joint of the stick. I replaced the joint and the stick itself and it was back to normal. Costed me only about $11.76
Pontuação 0
Adicionar a sua resposta
PingKDH será eternamente grato(a).
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 65
Últimos 30 dias: 144
Ao todo: 283
