Ir para o conteúdo principal
Modelo A1502 / processador 2,4, 2,6 ou 2,8 GHz de dois núcleos / Lançado em outubro de 2013
Video not displaying after attempted left speaker replacement
Tried to follow instructions but it didn't work out. Video is not displayed. Seems to do the bong start-up but no video. Help?
Esta é uma boa pergunta?
Pontuação 0
7 comentários
Please post some tight pics of the video cable (both sides) and the logic board connector as well so we can see what happened.
por
Weird as the speakers are nowhere near to the display connections.... can you be more descriptive in what you had touched inside?
por
@livfe I followed the instructions for replacing the left speaker on a MacBook Pro 13" retina. The battery cable and speaker cable were the items I took apart and put a new speaker in.
por
@danj I don't even know which cables are the video.
por
@michaeltakamoto Seems something was touched on the board causing a short which is affecting the display.... maybe time to take it to a specialist for diagnosis...@oldturkey03 @danj any thoughts?
por
Exibir mais 2 comentários
Adicionar um comentário
1 resposta
Solução escolhida
The culprit in this case was simply dust. Vacuuming out the motherboard to clean things up removed whatever was shorting out the video.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Michael Takamoto será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 237
