Ir para o conteúdo principal
O LG V60 ThinQ 5G, comumente chamado de LG V60, é um tablefone Android fabricado pela LG Electronics como parte da série LG V. Ele foi anunciado em fevereiro de 2020 e é o sucessor do LG V50 ThinQ. Em 5 de abril de 2021, a LG anunciou que encerraria sua divisão de telefones móveis e pararia a produção de todos os dispositivos restantes. A LG observou que o telefone estará disponível até que o estoque existente acabe.
Right channel audio gone
The right channel audio does not work (bottom loudspeaker, right channel with wired earbuds. bluetooth is fine). I've had this issue for a while, and I decided I would replace the parts that (I thought) were defective. I replaced the bottom loudspeaker, the 3.5mm jack, and the antenna/sound board (I had also done other repairs during this such as replacing the bluetooth antenna, the battery, and the charging flex cable, all of those seem to be working fine now. It should also be noted that my flex cable replacement and the antenna/sound board replacement were ordered separately and did not arrive as one piece.) Even after doing all of that, there is still no audio coming from the right channel. I honestly don't know what to do now.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I have this problem too.
And after cleaning these two part with contact cleaner and cotton swab, both speaker and headphones works fine again.
Imagem
Imagem
However, after the fix, the phone can't connect to PC anymore. and charger with QC doesn't charge with full speed; it only reach full speed with PD charger. I guess I broke something during the clean.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
beaviszep será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 198
