Ir para o conteúdo principal
Reparos e informações adicionais sobre a geladeira Frigidaire FRSS2623A*, um modelo de geladeira de tamanho completo de 2022, sem recursos integrados ou dispenser na porta, mas equipada com funcionalidade de degelo automático. Esta página contém informações para números de modelo que seguem o padrão FRSS2623A*.
Dispenser light doesn't come on automatically
Brand new fridge. Manual suggests the light above the ice/water dispenser should come on when used. It doesn't. The light works when manually turned on, but then stays on indefinitely. Ice, water, and all other functions of the unit seem to work fine. Can't find anything about this issue in official documentation or online, would appreciate any ideas!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
As an electrical engineer, I would assume there's a switch on the activation lever that is supposed to tell the control board to turn on the light when you press the paddle to get ice or water. I know there's one on my old GE fridge and my new KitchenAid as well. Like yours, they both have a separate button on the control panel to turn the light on manually that's independent of the paddle switch.
So my best guess here would be that you've got a defective switch on the dispenser. Of course, it could always be a bad connection or wiring problem, but I'd start with the dispenser switch. Unplug it and short the wires and see if the light comes on. If it does, boom, you've found the problem. Unfortunately, Frigidaire doesn't sell that switch as a replaceable part; instead you have to replace the entire dispenser assembly as one unit. It's number 8 on this diagram.
Imagem
However, given that it's a brand new appliance, it's going to be under warranty. So your first step before taking anything apart should be to contact their service department and explain the situation. Assuming they agree it should be working, they'll either suggest troubleshooting and/or repair procedures or send someone out to diagnose and repair the problem.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Just a note to the guy with the offensive name who felt compelled to call me an "egotistical $&!*":
It just so happens I am a retired electrical engineer. Why does my saying so bother you so much? Apparently you also missed the fact that I'm a moderator here on iFixit, and thus you're outta here!
por
Hi @dankemp98999
What is the full model number of the refrigerator?
The frss2623ad0 user manual only shows that the dispenser light is manually operated by selecting the light button on the control panel. No other way it can turn on is mentioned.
The service data sheet¹ for the above model, doesn't show a separate light switch for the dispenser. If it is supposed to turn on automatically when dispensing then it must be contained within the dispenser assembly.
¹ The service data sheet is applicable to all FRSS2623AB_, FRSS2623AD_, FRSS2623AS_ & FRSS2623AW_ models
Pontuação 1
Adicionar a sua resposta
Dan Kemp será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 62
Ao todo: 1,297
