Ir para o conteúdo principal
iPhone de 4 polegadas lançado em março de 2016 com especificações de hardware semelhantes às do 6S. Disponível nas cores prateado, cinza espacial, dourado ou ouro rosa com opções de armazenamento de 16/32/64/128 GB. Modelo: A1662 e A1723
Bluetooth lost range after battery replacement
I just changed out my battery using a kit I bought here at iFixit. It was a bit of a struggle but I got it done. However, now when I connect it to my Bluetooth speaker it starts breaking up if it moves more than like a foot away. I think the wifi is affected too but it's hard to tell (my wifi isn't great normally). I'm a little worried I might have broken something. Should I go back in and replace the antenna or are there other troubleshooting things I should do first before I open the phone again?
Note: I have performed several hard resets but the problem seems to come back in different ways. I think it is a problem with the range of the antenna.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You’ve bumped off or damaged the WiFi and Bluetooth antenna, which is that s shaped cable right above the battery.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I opened it up again and that is exactly what happened. It got caught under the battery and snapped when I was putting the battery in. Always look twice before shoving something in everyone!
por
Adicionar a sua resposta
Pat será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 221
