Ir para o conteúdo principal
A Samsung anunciou a linha Galaxy S24 no evento "Unpacked" em 17 de janeiro de 2024. O Samsung Galaxy S24 é o modelo base da linha de smartphones premium de 2024.
Screen + frame replacement Samsung S24
Hello!
I replaced the [screen+frame] unit on my S24, and the buttons ont the side of the phone don't work anymore. The screen works when I put the phone on charge but I only have a logo with the circle and the little lightning for a few seconds.
Can anyone help me to fix this please?
Thanks a lot :)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Is the phone charging? I know you see the lighting logo but, does the green circle increase? If so, we know the phone is atleast taking a charge.
The S24 replacement part with frame usually has the power button and volume button built into, so you dont have to transfer them. I would check to make sure though. Usually, you can tell if the buttons click properly or not.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks for your answer! No, the green circle doesn't increase. I had to transfer the buttons but I did it well and easily. The buttons click properly.
por
You're welcome. I would double check all the connections such as the battery and charge port. The fact that the battery isnt charging leads me to believe the charge port isnt being seen by the mainboard. Once the phone is taking a proper charge and you see progress on the screen that the phone is charging, I would test the power button again.
por
Adicionar a sua resposta
Haha Hihi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 23
Ao todo: 560
