Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
My ps3 does not get on
PS3 no yellow light ; fan turns shortly but does not get on
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Could be a lot of things! The most easiest thing is to test a new power supply and see if that fixes it.
Please be aware the many different models are out there. You should open it up to check which model you have!
If a new power supply didn’t worked, then you need to get the motherboard out and run some tests!
Guide: PlayStation 3 Power Supply Replacement
If you have any questions, please let us know!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Prince Legou será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 55
