Ir para o conteúdo principal
PlayStation 3 Power Supply Replacement
O que você precisa
  1. PlayStation 3 Power Supply Replacement, Smart Plate: passo 1, imagem 1 %32 PlayStation 3 Power Supply Replacement, Smart Plate: passo 1, imagem 2 %32
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
    Pergunte ao FixBot
    Comentar
  2. PlayStation 3 Power Supply Replacement: passo 2, imagem 1 %32
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
    Pergunte ao FixBot
    Comentar
  3. PlayStation 3 Power Supply Replacement: passo 3, imagem 1 %32 PlayStation 3 Power Supply Replacement: passo 3, imagem 2 %32 PlayStation 3 Power Supply Replacement: passo 3, imagem 3 %32
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
    Pergunte ao FixBot
    Comentar
  4. PlayStation 3 Power Supply Replacement: passo 4, imagem 1 %32
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
    Pergunte ao FixBot
    Comentar
  5. PlayStation 3 Power Supply Replacement, Top Cover: passo 5, imagem 1 %32
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
    Pergunte ao FixBot
    Comentar
  6. PlayStation 3 Power Supply Replacement: passo 6, imagem 1 %32
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
    Pergunte ao FixBot
    Comentar
  7. PlayStation 3 Power Supply Replacement, Memory Card Reader: passo 7, imagem 1 %32
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
    Pergunte ao FixBot
    Comentar
  8. PlayStation 3 Power Supply Replacement: passo 8, imagem 1 %32 PlayStation 3 Power Supply Replacement: passo 8, imagem 2 %32
    • Lift the memory card reader out of the PS3 enough to access its cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the memory card reader from the PS3.
    Pergunte ao FixBot
    Comentar
  9. PlayStation 3 Power Supply Replacement, Power Supply: passo 9, imagem 1 %32
    • Pull the DC-In cables toward the front of the PS3 to disconnect them from the power supply.
    Pergunte ao FixBot
    Comentar
  10. PlayStation 3 Power Supply Replacement: passo 10, imagem 1 %32
    • Lift the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
    Pergunte ao FixBot
    Comentar
  11. PlayStation 3 Power Supply Replacement: passo 11, imagem 1 %32
    • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
    Pergunte ao FixBot
    Comentar
  12. PlayStation 3 Power Supply Replacement: passo 12, imagem 1 %32
    • Remove the five 9 mm Phillips screws securing the power supply to the chassis.
    Pergunte ao FixBot
    Comentar
  13. PlayStation 3 Power Supply Replacement: passo 13, imagem 1 %32
    • Lift the power supply upward from its front edge to disconnect it from the posts attached to the logic board.
    • Remove the power supply.
    Pergunte ao FixBot
    Comentar
Conclusão
49 outras pessoas executaram este guia.
6Comentários do guia
This is for the 60gb version. As there is no card reader in the 80gb i replaced the power supply in and some of the psu screws were in a slightly different place. But a very good guide.
Craig Taylor - Responder Compartilhar
I have a Ps3 that was bought in America. The power supply is different to ours here in South Africa (Cape Town). A friend who gave me the Ps3 also had an external power supply built so that it can be used here. It's been working for years but now I have that green light thingy going. I've removed the disc that was in it and thought it may have been inserted incorrectly. Now that I have seen your tutorial I will definitely check if it's the power supply or mother board. Thank you.
patrickms - Responder Compartilhar
CAN I HAVE THE MANUAL MY RED LIGHT IS ON ALSO DIRECT ME TO A GOOD PLACE FOR REPAIRS IN ACCRA GHANA EMAIL honmante54@yahoo.com thank you
honmante54 - Responder Compartilhar
why do your consoles have this red light on why do something about it
Hi I need a good fix store in Greece for ps3 in order to replace my power supply
Manos Kallimanis - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 80
Últimos 30 dias: 347
Ao todo: 118,835
