Ir para o conteúdo principal
Discover the Craftsman Gas Snow Thrower 247.88787, a machine designed to clear snow from driveways and walkways using a rotating blade system. This page offers repair and detailed information about this gas-powered device, including its fuel capacity of 2.3 quarts and usage of 5W-30 engine oil.
1 Perguntas Visualizar todos
Governor does not seem to be adjusting engine RPM
How do you test or know if the governor is working. I recently replaced the carburetor due to hunting and surging. The issue is resolved however now the snow thrower runs at WOT unless I choke it almost all the way.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @nelso78280
What is the make and model number of the engine, used in the snowblower?
Here's a video that shows how to set the governor in a Tecumseh engine that may gives you some ideas of what to check.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
nelso será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 12
