Ir para o conteúdo principal
Guia de reparo e informações de resolução de problemas para o mouse sem fio da Apple com suporte multi-touch. Número de modelo A1657 ou A3204.
Cannot on - cannot detect device in bluetooth MacBook
My magic mouse 2 can't turn on (I think) even though it's been charged for a long time. And the MM2 can't be detected in the macbook pro bluetooth. Other devices are ok.
This problem occurs when I don't use the MM2 for a long time - 1 week or more (turn on) in the bag.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If your Magic Mouse 2 isn't turning on or being detected by your device, here are some troubleshooting steps to try:
1. Check the Power Switch
2. Restart Bluetooth
3. Check Bluetooth Connection
4. Try Pairing Again
5. Check for Interference
6. Test with Another Device
Ensure your Mac’s software is up to date by checking in System Preferences > Software Update.
Sometimes a software update might resolve Bluetooth connectivity issues.
If none of these steps work, it could be an issue with the mouse's hardware. In that case, you may need to contact Apple Support for a replacement or repair.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ag Marjokni Mohd Johari será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 32
Ao todo: 354
