On/off switch wire colors
Which wires do I use to bypass bad switch?
Esta é uma boa pergunta?
Shorting the Pins:
To bypass the switch, you need to connect the green or blue wire (power wire) to the black wire (ground wire). These wires are usually located on the motherboard's front panel header.
Do not leave the pins shorted for more than a second, as that could cause electrical damage.
It’s important to replace the faulty power switch at your earliest convenience. If you're not comfortable doing this, or if it doesn't resolve the issue, it may be best to take the desktop to a professional.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 206
