Ir para o conteúdo principal
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
20 Perguntas Visualizar todos
Gameboy advance SP Red Screen Tint
Hi, I bought this GBA SP 101 on ebay and it has this red filter on the screen and is mainly noticable on black screens. Is this caused by the ribbon cable or the polarizing film? Or something else?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi!
Could be both actually. Only thing to do is to disassemble it and check the ribbon cable and screen. Unfortunately, you probably need to replace the screen (cable is fused) to fix this.. Sorry!
Esta resposta foi útil?
Pontuação 1
Here are some causes and potential solutions if your Game Boy Advance SP (GBA SP) screen appears red.
Possible Causes:
Inspect the Battery: Display distortions (including color tints) can occur if the battery is low or failing.
LCD Damage — A defect or degradation in the screen itself.
Screen ribbon cable problem; A loose or faulty ribbon cable is responsible for causing color distortion by connecting the screen to the motherboard.
Backlight Type: If you own a front-lit (AGS-001) model, the lit screen can on occasion
Pontuação 0
Adicionar a sua resposta
Sonrai será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 26
Duração total: 44
