Sound stops after a few minutes
Radio plays sound for a few minutes a then the sound goes out. If I turn vehicle off then turn it back on it works just for a few minutes. It’s a brand new new radio definitely no loose connections or over heating an no bad fuses
Esta é uma boa pergunta?
Hi @walterrayborn
Does it also do this when using the radio on Accessories power only i.e. engine not turned on?
Have you checked the speakers are the correct value for the radio i.e. >50W power rating, 4-8 Ohms impedance?
por jayeff
When I have the vehicle running it plays sound for about 2 minutes or so then stops playing sound then I’ll have to turn vehicle back on
por Walter Rayborn
I mean I have the vehicle running it stops playing sound after about 2 minutes then I’ll have to shut the vehicle off then turn it back on for it to play but keeps doing that every time
por Walter Rayborn
@walterrayborn
Yes but does it play continually without the engine running at all or does it also turn off after 2 minutes or so?
If it plays continually I was wondering if there's a difference between battery power only and power from the alternator when the engine is running.
Does the radio turn off completely or only the sound stops?
Just trying to eliminate possibilities
por jayeff
Just the sound quits radio is still on
por Walter Rayborn
Exibir mais 1 comentário
