Ir para o conteúdo principal
The 32" monitor designed to complement the 2019 Mac Pro. Released in December 2019.
3 Perguntas Visualizar todos
How to fix and/or replace cracked glass?
I have a crack in the glass above the display / LED layers that’s propagating throughout the length of the screen. This display itself still works fine. Curious if any one knows how to replace the glass on top.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Oh boy! What a pickle of a mess!
Sadly, the way Apple constructed the display makes replacement of the front glass very close to impossible.
Getting the display assembly off follows the same process as the newer iMac’s using the pizza cutter, then once you get the assembly off, you next need to take the backlight unit off and then the defuser sheets. Next is separating the LCD panel from the cover glass this is where the risk of damage to the LCD panel as like the iMacs there is a gummy foam seal that holds the two together. I have yet to see anyone either get the panel off without damage or leaving a mess on the glass or the fragile LCD panel which is very difficult to remove.
While very expensive you really will need to let Apple replace the screen assembly as there is a needed calibration procedure to make the zone backlight to work properly.
Esta resposta foi útil?
Pontuação 0
You can’t.
Apart from the extremely risky taking apart process and not able to get parts, you’ll need a bonding and debubble machine as big as that giant display, which nobody makes for repair shops.
Industrial versions that are used in the display factories exist, but that thing is the size of a CT scanner and probably cost as much as a new car.
Pontuação 0
2 comentários:
@tomchai - Don’t confuse an iPhone or iPad laminated display. Unlike them there is an air gap between the inside surface and the top of the LCD panel.
por
@danj I have not even seen one in real life, not even at the Apple store, I assume they've already gone all in with lamination.
por
Adicionar a sua resposta
JDC será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 112
