How to change LCD screen
Esta é uma boa pergunta?
Changing the LCD screen on a Realme C15 requires patience and careful handling. Here’s a step-by-step guide:
Tools Needed:
New LCD screen for Realme C15
Plastic opening tool or spudger
Phillips screwdriver
Heat gun or hair dryer
Suction cup
Adhesive or double-sided tape
Steps to Replace LCD Screen:
1. Power Off & Remove SIM Tray
Turn off the device and remove the SIM tray using a SIM ejector tool.
2. Remove the Back Cover
Use a plastic opening tool to carefully pry open the back cover.
Be gentle, as Realme C15 has clips holding the cover in place.
3. Disconnect the Battery
Unscrew the metal cover protecting the motherboard.
Use tweezers to disconnect the battery connector to avoid a short circuit.
4. Remove the Motherboard Cover & Screws
Remove all visible screws securing the LCD screen and motherboard.
Carefully disconnect the LCD ribbon cable and touchscreen connector from the motherboard.
5. Heat & Remove the Broken Screen
Use a heat gun or hair dryer to soften the adhesive around the LCD.
Gently lift the broken LCD using a suction cup and plastic tool.
Clean any remaining glue from the frame.
6. Install the New LCD Screen
Align the new screen and connect the ribbon cable to the motherboard.
Secure it in place with adhesive or double-sided tape.
7. Reassemble the Device
Reattach all screws, reconnect the battery, and place the back cover.
Insert the SIM tray and power on the device.
Final Check:
Ensure the touchscreen and display work properly.
If the screen is unresponsive, check the connectors.
⚠️ Note: If you're unsure, it's best to take your device to a professio
nal repair shop to avoid damage. Let me know if you need help with any step!
Esta resposta foi útil?
Please be aware when referencing this answer that all indications are that it is AI-generated. While that is not necessarily bad, we do require that it be fact checked by a knowledgeable human, and we do not know if that is the case here.
Why would you heat up the screen once you're inside the phone? You would need to heat up the screen to undo the adhesive and get inside. That comment is definitely ai, so follow it with caution.
@cactus12 Actually, on most Android phones you have to open up the back to access the display connector, then separate the LCD from the midframe using heat so it can be removed. In that sense the AI instructions are not inaccurate, but are pretty general. Not sure I'd attempt a repair using just those instructions, myself.
Whoops, I messed up, I should've caught that. Thanks for the correction.
Screen recorder
Two words is all we get? It's not at all obvious what kind of help you're looking for, Manoj. Please give us more information about what's going on with your phone and what you want to accomplish. Otherwise we'll eventually just archive your question as unanswerable.
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 59
Ao todo: 1,348
1 comentário
Phone screen
por Muni Sharma
