Touchscreen issues after battery replacement
Imagem
I changed the battery of my Apple Watch SE 40mm. Everything went well until I tested the watch—the touchscreen no longer works. Of course, I checked the flex cables behind the screen, and they are properly connected. Only the tape on the flex cables was damaged. Could this be the cause? thanks a lot
Bonjour tout le monde, j'ai changer la batterie de mon apple watch Se 40mm, tout a bien été jusqu'au moment ou tester la montre, l'ecran tactile ne fonctionne plus, j'ai bien sur verifier les nappes derriere lecran, elles sont bien mises.... il y a que le scotch des nappes qui a été endommager, cela pourrait il venir de ca? je vous remercie
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
