How to remove keyboard?
How do I remove the keyboard on the ZBook 15v G5? I have already removed the bottom cover and the battery.
Esta é uma boa pergunta?
Like many of the HP models from this general time frame, the keyboard itself is not independently replaceable. It comes as part of the "top cover" assembly. There may be ways to replace it by itself, but it will likely be a tricky process because of the way its attached to the top cover.
Essentially you need to remove just about everything from the housing to get to the keyboard underneath.
The actual Service Manual for this model is available for download directly from HP with the full directions.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 35
Ao todo: 330
