Ir para o conteúdo principal
Suporte para a calculadora Texas Instruments TI-84 Plus.
Line of keys not working.
I've had my calculator for years and use it frequently. Today, an area of keys - specifically "0", "1", "4", "7", ",", "sin", "apps", "x^2", "(", ")" stopped working. All other keys work fine. I've tried restarting, system reset, and changing batteries. I don't know if it's possible water damage (I have cats) or something else.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If a column of keys stops working that typically means it's a hardware problem. You might have success taking the calculator apart and cleaning the button side of the circuit board with isopropyl alcohol.
However, it's likely you'd also need to do a board level repair using soldering equipment. Water damage and corrosion can certainly cause issues like this.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Milo Moss será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 18
Ao todo: 137
