Ir para o conteúdo principal
Cannot get Onn Tablet Recovery Mode
I have a 32GB Onn tablet, the 2024 model, that I cannot get into recovery mode to perform a factory reset on the tablet. I was sold this tablet with an unknown pin, and I cannot get into recovery mode with the button combos I found online. It seems that on last year's model, you would press power and volume up until white text pops up on the screen, prompting you to enter recovery mode; however, when I do that on this model, it just stays black. If I hold power and volume down, it will just boot normally. I have tried putting in random pins 20+ times to trigger a factory reset. I am at a loss for words. If anyone can help, that would be great.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I just figured out for mine after getting no luck with searching...I held the Power and Volume Down (the one not closest to the Power button) for about 4 seconds, then let go of the Power button but kept the Volume button down and it finally appeared!
Esta resposta foi útil?
Pontuação 0
3 comentários:
Unfortunately it does not appear to be working on mine.
por
When i do that mine shuts off and does not turn back on. If I let go of the power button before it shuts off, it just boots normally.
por
Mine does the exact same as yours did you ever find a fix for it?
por
Adicionar a sua resposta
Jonathan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 73
Ao todo: 711
