Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Need help with with the right SSD Enclosure/Adapter
I need help with hardware compatibility for an SSD enclosure. The one I bought isn't correct, though the listing said it was only either 2.5 or 3.5. This is what I bought: https://www.amazon.com/dp/B0C73VYQCW?ref...
If it is right I can't see how it fits. Can you please point me to the right one, maybe just an adapter since I won't need durable use. Thanks for your kind reading.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The storage drive in the Retina 2012 15-inch MacBook Pro is not a 2.5 or 3.5 inch drive, its a specialized blade SSD. This is the enclosure you want (as far as I know they're only made by OWC).
Esta resposta foi útil?
Pontuação 1
1 comentário:
Will do Zach. Many thanks!
por
Adicionar a sua resposta
Pamela Wilson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 84
