Ir para o conteúdo principal
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
20 Perguntas Visualizar todos
Height difference between TB display stand and iMac A1312 stand?
I have a VESA mounted Thunderbolt Display that i would like to convert back to a regular stand. I have noticed that the A1312 iMac 27" stands seem to be cheaper, and they connect via the same mounting system, so I am wondering if there is a height difference between it and the OEM stand. Mainly looking for something like a picture of them side by side if that is possible to get as my google searching is yielding nothing. Thank you.
Edit: I have bought an A1312 iMac stand and it seems to fit fine. It’s about 9cm from the desk to the bottom of the display so if any other Thunderbolt Display owners would mind measuring to see if they are the same or not that would be awesome. Here are some pics of it all mounted up.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @thequacker,
Don't know if the height specified in the following is the total height or just the height of the display:
27" Thunderbolt display height = 19.35 inches (49.1 cm)
A1312 iMac display height = 20.4 inches (51.7 cm)
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Duck será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Ao todo: 37
