Ir para o conteúdo principal
Reprodutor de Blu-ray 4K Ultra HD, 3D, com áudio de alta resolução e Wi-Fi integrado
Device isn't starting anymore.
Strange thing, when the player is plugged in, if I hit the eject button on the player, the drive will open and close no problem. However, the device doesn't actually power up.
This includes when I push the power button on the device as well as on the remote. The power light indicator doesn't turn on, the software doesn't start up, even though again, the drive opens and closes just fine.
I've tried factory reset, I've tried using a different power cable, no change.
I should say that I've moved recently and it was working before the move but not after.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @mistersteel
It could be a loose connection between the boards in the player or something a bit more technical.
Here's the start of the troubleshooting section from the service manual, that may help to find out what's wrong.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
mistersteel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 385
