Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Home TheaterDVD PHILIPS. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Home TheaterDVD PHILIPS.
Yamaha MCR-042 - Problem with CD player
Hi @jayeff I have a slightly different issue but I'm hoping you can help.
I have a Yamaha MCR-042. It struggles to pull in a CD but will with a little help. The main issue is that the cd-player won't 'recognise' the CD on occasion. It'll take in the cd, and the motor will keep running as if the CD hadn't been inserted and it's still trying to pull something it. Then, it will spit it back out. Some trial and error made me think it was the orientation of the CD itself, and some CD's have different labelling on the data side (serial numbers, or bar codes) - I thought the bar coded CD were the ones that would be recognised, but that's wrong. It's also nothing to do with the colour of the CD - I painted the label side of a light coloured CD black and it still wouldn't accept it.
Do you have any advice? I would appreciate it. If you'd prefer I post a new thread, I will.
Best,
Lucas
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @lucasac
Here are a couple of things that you can check.
1, Not recognizing the cd disc could simply be a dirty laser lens. Try cleaning the lens either by using a commercially available cd/dvd lens cleaner kit (examples only) or if you have opened the disc drive (see below) to gently clean the lens with a Q-tip lightly moistened with Isopropyl Alcohol 99%+ (available from electronic parts stores).
2. Regarding "...struggles to pull in a CD..."
The player is a slot loading cd disc player type which means it has a motor driven mechanical action that grabs the cd and pulls it in. There's a rubber roller which is used and if it is dirty or has worn down it isn't grabbing the disc that well anymore.
Here's a video that shows how they work.
You can try cleaning the roller using the method shown in this video and check if it resolves this problem.
If no good you may have to open the player to access the disc drive and check if the roller needs a better clean or if it is worn. If it's worn then, finding the service manual (I can't find it -you may have better luck) would help as mostly they have a parts list and it would be easier trying to find a part by searching for the part number as opposed to looking for it by using the make and model number of the device.
If all else fails you could try replacing the disc drive unit. Hopefully there's a part number to be found somewhere on it, that you could search for online.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you so much! I'll give both ideas a go. I appreciate it.
Lucas
por
Adicionar a sua resposta
LucasAC será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 36
Ao todo: 354
