Ir para o conteúdo principal
Repair guides and support for water softening systems.
5 Perguntas Visualizar todos
CSI signature series (1) control valve troubleshooting
Hi we have error code 3 which is an issue with the control valve? I think I need to take the cover off and check for debris? The manual is very vague and unhelpful.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@shellyhyatt take a look at this CSI Signature Series SM and see if that pertains to your valve as well. Error 3 - Encoder is not sending a signal (Valve requires service to continue)
Yes, I would definitely consider opening it up and to take a look at it. See what you find. You could be looking at debris as well as corrosion etc.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yup! Ty - I have the paper manual and all it has it that code explanation and the exploded diagrams. I will try to find the screws and see what I can do/see:)
por
Adicionar a sua resposta
Shelly Hyatt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 53
