Ir para o conteúdo principal
{A1706 / EMC 3071}—Lançado em junho de 2017, este MacBook Pro de 13" possui processadores Kaby Lake de até 3,5 GHz Core i7 com Turbo Boost de até 4,0 GHz.
How to change the keycaps
I need to replace the keycaps on a old touch bar MacBook pro is there anything that I should know as I'm used to PC laptops and have never worked on a MacBook is there anything that I should know?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
These key caps are extremely easy to break. So going in prepared is key. :)
If you haven't taken a look at the internals of the key switch here's a picture that will probably help more than anything.
Imagem
This image is a bit newer model, but the mechanism is largely the same. The key to damage free removal is to use something slim (like iFixit's Jimmy or an iSesamo) to get under the top edge of the key cap. That's the side with the clips, and the bottom edge has a little hinge in each corner that can take the posts on the key switch out too if you're not gentle.
There's also a Guide if you want a more step by step.
Imagem de Springy steel blade features a smart tip design and a handle with a great no-slip grip. Effortlessly pops open iPod, iPad, iPhone and many other tablets, smartphones, and devices.
Produto
iSesamo Opening Tool
$10.99
Imagem de Handy tool for opening electronics.
Produto
Jimmy
$7.95
Esta resposta foi útil?
Pontuação 2
Here is a good video that shows you how to replace the keys :)
Pontuação 1
Adicionar a sua resposta
frey_code será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 288
