Ir para o conteúdo principal
A sports sedan manufactured in 2003-2004 by Infinity
Car wont start after fixing stuck gear shifter
Why won't my car start? I was turning the car around and when switching it from reverse to drive i accidentally pushed the shifter over to the manual or stick shift side of the gears. ( Car is a automatic and stick shift but it doesn't have a clutch) *I know very little about cars so excuse me for not knowing the correct terminology or names of the parts I'm talking about) So I pressed the tiny button by the gearshifter to unlock the gearshifter and put it back into automatic but now the car wont start. It cranks, lights radio air everything comes on but it just doesn't turn over. Please help.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Unfortunately none of these worked. I used an old scanner and no codes came up. The VLC light stayed on for about 10 seconds then flashed 5 times then went off. I looked that up and it said it means it's not ready for emissions inspections not sure if this just means it's not ready to smog or if it's related to my issue.
por
Adicionar um comentário
1 resposta
It sounds like your car’s issue might be related to the gear shifter position or a safety feature preventing the engine from starting. Here’s a step-by-step guide to troubleshoot and possibly fix the issue:
1. Check the Gear Position
  • Ensure the car is in Park (P) or Neutral (N) before attempting to start it.
  • If it’s not fully in Park or Neutral, the car's safety system will prevent it from starting.
2. Recheck the Shifter Mechanism
  • Since you pressed the small button near the gear shifter to manually unlock it, the linkage may not have returned to its proper position.
  • Wiggle the shifter slightly while trying to start the car (in Park or Neutral).
3. Inspect the Brake Pedal
  • Make sure you're pressing the brake pedal firmly when trying to start the car.
  • If the brake light switch is faulty, the car may not detect that the brake is being applied, which can prevent it from starting.
4. Test the Battery
  • Even though the lights and radio are working, the battery may not have enough power to turn the engine over.
  • Try jump-starting the car to rule out a weak or discharged battery.
5. Check for Faulty Neutral Safety Switch
  • The neutral safety switch prevents the car from starting unless it's in Park or Neutral. If this switch is misaligned or damaged, it can cause starting issues.
  • This would require professional inspection or adjustment.
6. Look for Error Codes or Indicators
  • If your car has a dashboard indicator light or message (e.g., a flashing gear symbol), it could be signaling a transmission-related problem.
  • Plugging in an OBD-II scanner can reveal error codes that might help diagnose the issue.
7. Try a Reset
  • Turn off the car completely, remove the key, and let it sit for a few minutes.
  • Reinsert the key, ensure the shifter is in Park, and try starting it again.
8. Transmission Interlock Issue
  • The manual override of the gear shifter might have caused a temporary misalignment in the transmission interlock system. In some cases, moving the shifter through all gears and back to Park can reset this system.
When to Call a Professional
If the car still won’t start after these steps, it’s best to consult a mechanic. Possible issues could include:
  • Faulty ignition system (e.g., starter or solenoid).
  • Problems with the transmission or shift linkage.
  • Malfunctioning sensors (e.g., brake light or neutral safety switch).
Let me know how these steps work for you or if you need further assistance!
Esta resposta foi útil?
Pontuação 0
2 comentários:
I will try these as soon as I get home thank you so much for the fast reply and help. Will keep you updated.
por
Did any of the suggestion's work?
por
Adicionar a sua resposta
Holly Higgins será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 20
Ao todo: 482
