Ir para o conteúdo principal
Modelo A1312 / Meados de 2010 / Core i3 de 3,2 GHz ou Core i5 de 2,8 e 3,6 GHz ou Core i7 de 2,93 GHz, ID iMac11,3
Converting the system into a display
HI, Dan. My interest was primarily forward-looking. I currently am using a 27" iMac (Mid 2010) and anticipating it's demise.
Thinking about acquiring a Mini, but really like the 27" display, so when I stumbled across this thread, thought I'd explore further. (I'm using this thread because I didn't think of asking a separate question.) I'm not a "hobbyist" or computer expert, but do have some experience on electronic devices in general, so... Hope I didn't mess up this thread; it certainly wasn't my intention to hijack it, I just didn't know any other way to contact you.
Esta é uma boa pergunta?
Pontuação 0
7 comentários
@danj, can you point us in the right direction for obtaining the interface board you mention above? TIA!
por Compartilhar
@doug12716 - Answers (here) is where a collection of volunteers help people.
This series still has a useful life as a computer! Just by updating its OS. I can see other older systems which make sense converting as the last option, and I can see a dead system might be a good candidate as well.
Both directions serve the goals of reuse, but clearly in this case saving the system was the better choice.
Dropping is as you did without context (or better asking your own question independently) means we are left not understanding what your point was.
Yes, GitHub is not the easiest place to navigate or find help, which is why we have a guide on OpenCore! And the PC doc I also linked too often answers the deeper questions.
por Compartilhar
@doug12716 - I’ve moved your question into its own question so we don’t distract others as the conversion kit is different for the older systems from the 5k display the other system had.
por Compartilhar
@doug12716 make sure that you get a high quality driver board. Biggest complaint with these boards is that the brightness is less than what you are used to from your iMac.
por Compartilhar
@oldturkey03 , how might one ascertain the quality? Price isn't always a reliable indicator, eh? Do you suggest just "googling" the mfgr? (Most electronic items seem to be built in China, so info is often limited...)
por Compartilhar
Exibir mais 2 comentários
Adicionar um comentário
1 resposta
Solução escolhida
For your system you will need this driver board 27” iMac A1312 A1316 A1407 2K LCD Controller Board Monitor Display kit For LM270WQ1 A2 C2 E3 F1 B3 screen driver board and here’s the guide to open your system up to clean out what’s not needed Transformação do iMac Intel 27" EMC 2390 em um monitor externo 2K HDMI/VGA
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you, sir! Very much appreciated! Have a great Turkey Day!
por Compartilhar
Adicionar a sua resposta
Doug será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 122
Ao todo: 3,724
