Ir para o conteúdo principal
Este Moto G com tecnologia 5G possui uma tela LCD de 6,5 polegadas, 720 x 1600 pixels e 90 Hz, chipset MediaTek MT6833 e câmeras grande-angular de 50 MP, macro e de profundidade.
How to clean proximity sensor?
The display on the top side got unglued a few weeks back and I didn't bother to fix it. Now after ending phone call the proximity sensor turn off my display until I lock and unlock using buttons.
I believe it is due to some dirt accumulated on the sensor. What is the best way to clean it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I would run a hardware test on your phone to confirm this. There's a convenient iFixit guide for this. Secondly, you'll need to tear down the device a bit to clean it. I'm unsure if you'll need to remove the LCD panel, but there's a repair guide. You can clean it with some Q-tips and some isopropyl alcohol, but I can't give too much guidance on that.
If cleaning doesn't work, I can only recommend replacing the device's LCD frame or mid-frame housing. The mid-frame housing does contain some small components, potentially the proximity sensor. Also, it's essential to ensure you place proper adhesive post-repair.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kishore Kumar S será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 370
